1995 Suzuki Esteem Fuel gauge
1995 SUZUKI ESTEEM
138,000 MILES • 4 CYL • FWD • MANUAL
DIGITALEXCLUSION
  • 20 POSTS
My question is in regards to the gas gauge. When the tank is full the gauge is correct, but it seems that the needle approaches empty way too fast. When the needle is on empty and I fill up the tank, on average it'll fill up with 8 or 9 gallons. From what I can tell the capacity of the tank is 13.5 gallons. What are some things that I can check to see what's causing this? I just want to know that the gas gauge is working properly. Please let me know if you have any questions.
Thanks!
Oct 18, 2009 at 11:24 PM
KHLOW2008
  • 41,814 POSTS
Hi digitalexclusion,
Thank you for the donation.
When the gauge shows empty, does the low fuel warning light come on?
Previously was the gauge showing differently?
From the symptoms, I would suspect the fuel sending unit in fuel tank rather than the gauge itself.
Due to technical problems I am having slow browsing speed, ISP fault, I am not able to access our database and is unable to provide you the testing specifications for the sending unit.
Hopefully when the problem clears later I can get them and post it for you.
Oct 19, 2009 at 8:23 AM
DIGITALEXCLUSION
  • 20 POSTS
Hello KHLow2008,
Thanks for the follow-up.
When the gauge shows empty the fuel light does NOT come on. I question even if the car has a low fuel light because I've never seen it.
I've owned the car for 2 years and the gauge has always been acting like this...I just never had the time to try to figure out what's going on.
Please let me know about the fuel sending unit and how to check/replace it. Hopefully it doesn't require removal or replacement of the fuel tank.
Thanks again!
Oct 19, 2009 at 8:42 PM
KHLOW2008
  • 41,814 POSTS
The sending unit is located in fuel tank and removal installation takes 2 hours. Fuel tank would have to be dropped to get at it. If low fuel warning lamp is equipped, you would notice a bulb type unit at lower end of sending unit and there would be 3 wires instead. FUEL GAUGE SENDING UNIT Remove fuel gauge sending unit from vehicle. Connect an ohmmeter between sending unit connector terminals. See FUEL GAUGE SENDING UNIT RESISTANCE . If resistance is not as specified, replace sending unit.
https://www.2carpros.com/forum/automotive_pictures/192750_FuelGauge95EsteemFig03_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_FuelGauge95EsteemResistance_1.jpg
Oct 20, 2009 at 12:09 PM
DIGITALEXCLUSION
  • 20 POSTS
Thanks for sending the diagram. Do you have instructions on how to drop the fuel tank?
Oct 20, 2009 at 5:27 PM
KHLOW2008
  • 41,814 POSTS
I am not ble to find any diagrams to show how to drop the fuel tank and would rely only on written instructions. 1 . Keep fuel level low before starting work to reduce the weight of the tank and also avoid spillage. 2 . Release fuel pressure FUEL SYSTEM PRESSURE RELEASE CAUTION: DO NOT perform this procedure when the engine is hot. Doing so may have an adverse effect on the catalytic convertor. a . Place transmission in Neutral (M/T) or Park (A/T). Set parking brake and block drive wheels. Disconnect fuel pump relay from relay box. Relay box is located between battery and shock tower.
https://www.2carpros.com/forum/automotive_pictures/192750_FuelPumpRelay95EsteemFig02_1.jpg
b . Remove fuel filler cap to release fuel vapor pressure in fuel tank. c . Reinstall fuel filler cap. Start engine and run until engine dies. After engine dies, crank engine 2 -3 times for about 3 seconds to dissipate fuel pressure in lines. To restore normal operation, reconnect fuel pump relay connector. 3 . Raise and support vehicle on stands. 4 . Use floor jack to support fuel tank. 5 . Remove fuel tank holding bolts. 6 . Lower fuel tank slightly and disconnect fuel, inlet and vacumn hoses. 7 . Disconnect wire couplers. 8 . Lower fuel tank 9 . Remove the fuel sending unit by removing the holding screws/nuts.
Oct 21, 2009 at 7:31 AM
