drive shaft joint constant velocity boot
2010 SUZUKI ALTO
43,000 MILES • 1.0L • 4WD • AUTOMATIC
IAN NESS
  • 7 POSTS
Drive shaft joint constant velocity boot severely deteriorated nearside front inner on a car.
Apr 28, 2021 at 11:43 PM
Unfortunately we don't have a manual on this vehicle as it is not offered here in the USA. However, here are a number of guides that will help with this repair.
https://www.2carpros.com/articles/how-to-replace-a-cv-axle-bearing
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/replace-cv-axle
Below you will find the info from a like vehicle is offered in the USA and it should be very similar.
Please run through this material and hopefully it gets you the info that you need. Thanks
Apr 30, 2021 at 7:21 PM
IAN NESS
  • 7 POSTS
I just had my car serviced, would they check the CV axle for repair?
May 1, 2021 at 12:33 PM (Merged)
When you indicate it was just serviced, what was done? As far as checking CV axle joints, if a visual inspection was done, chances are they inspected the boots to make sure there aren't damaged or leaking.
Are you having issues with a joint? If so, can you explain to me what is happening? The most common indication of a bad joint is a clicking sound when turning sharp. Here is a link that explains how the joint works:
IAN NESS
  • 7 POSTS
Where is the drive shaft joint constant velocity boot severely deteriorated nearside front inner on a car.
May 1, 2021 at 12:34 PM (Merged)
I assume you are talking about the front CV axle. Here are some guides that will help with this:
Below you will find the process from a like vehicle that is offered here in the USA. Unfortunately we don't have a manual on this vehicle so this process will be pretty close to what your vehicle has.
Let us know if you have other questions. Thanks
