2004 Suzuki Alto Rear Wash Motor
2004 SUZUKI ALTO
GERRYD544
Electrical problem
2004 Suzuki Alto 4 cyl Front Wheel Drive Manual
At the moment, rotating the column switch does not produce any water to the rear window. No motor noise. Could this be a fuse problem? Also where is the motor located?
Jan 14, 2010 at 2:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
thanks for donating!
yes, need to first check the washer fuse. If fuse is OK (most likely is if wipers still work) then check washer hose and / or nozzle for clogs. Since you say pump isn't heard, most likely this is a washer pump failure though. The washer pump will be located on or near the washer tank itself, under hood.
Jan 21, 2010 at 4:51 PM
