2004 Suzuki Aerio is this a short or the transmission senso
2004 SUZUKI AERIO
MSSWEETE118
Electrical problem
2004 Suzuki Aerio Automatic 103000 miles
I am having a problem with the transmission range sensor i think. the car drives fine until i turn on the headlights, then it seems like it kicks into low gear and the transmission starts whining. if i turn the headlights back off then the car goes back to normal.
the prndl doesnt register right when lights are on if car is in drive it will register reverse or the lit up R or D will go out and nothing will be lit up. i need a diagram of the two relay boxes that are under the hood on the drivers side. one is square and one is rectangle. also, i need step by step instructions on how to change the sensor located by the shifter. any help would be greatly appriciated.
Dec 9, 2008 at 8:00 PM
DAVE H
  • 13,384 POSTS
have the vehicle plugged into a diagnostic scanner to locate the cause of the fault !!
Mar 24, 2009 at 9:38 PM
