Don't forget to bench-bleed the new master cylinder.
Here's a trick that can save you a real lot of time. I forgot to post this earlier. This may not work as well on Fords that have four steel lines leaving the master cylinder, but it works well on all other car brands. Slightly loosen the two steel line nuts on the master cylinder. Unbolt it from the booster, pull it forward, then use it as a handle to bend the steel lines upward a little. That will prevent the fluid from running out of the lines. Remove the lines, connect them to the new master cylinder, use it to bend the lines back down and install the new master cylinder to the booster. Snug one line nut and leave the other one loose. Have a helper slowly push the brake pedal half way to the floor. It should take about ten seconds for him to get there. When he hollers he's ready, or you no longer see air bubbles coming out, snug that line, then have the helper release the pedal quickly. Loosen the nut and do that a second time or until no more bubbles come out. Do that for the other line next.
By pushing the pedal slowly, fluid gets pushed down into the line and air has a chance to float back up. By releasing the pedal quickly, the fluid rushing back will wash any remaining air bubbles up into the reservoir. You'll never have to bleed at the wheels this way, or risk breaking off a bleeder screw.
Be extremely careful to not get any hint of petroleum product like engine oil, transmission fluid, power steering fluid, or penetrating oil anywhere near parts that contact brake fluid. That will destroy all the rubber parts in the hydraulic system.
Apr 12, 2018 at 3:55 PM
