I have checked all ball joints. I've changed both upper control arms due to worn bushings. I've changed both upper ball joints. I've checked entire suspension system in front and rear. I keep hearing a rattling noise coming from the front passenger side or so it sounds like that. No noises when I pass over bumps on roads though. I checked the sway bar bushing and links. Everything seems fine. Now for the last couple days the noise is starting in the rear too. I just can't figure out where the noise is coming from. I have a front CV shift to replace. That is one thing I can hear at low speed. But everything else is a mystery. I've inspected the entire front suspension but can not pin point where the noise is coming from.
Aug 12, 2021 at 5:52 PM
