Bad vibration in the steering
1997 CHEVROLET S-10
100,000 MILES • 4.3L • V6
DUSTIN MORRIS
Replaced both times and tires. Lugs constantly becoming loose and has eventually started to break off studs. Suspension or wheels?
Apr 16, 2019 at 6:31 AM
Welcome to 2CarPros.
I need to know if this is 4wd or 2wd. Also, you replaced tires. What else was replaced? you indicated that " Replaced both times and tires." What is meant by times? If you could, let me know if there are any noises associated with the vibration or when driving, and if the wheels have been inspected for runout. Have you inspected wheel bearing or hub bearings? Is the problem always or only when brakes are applied?
Apr 16, 2019 at 10:21 AM
