While driving on a robust road there is a noise from front left side. What is the reason and please give me solution to the problem.
Feb 27, 2018 at 1:40 AM
MHPAUTOS
CERTIFIED EXPERT
Check for oil leaking from the strut, if it is leaking the strut will be quite wet. Also, check for a broken sway bar link and worn lower arm bushes and lower ball joint. are you familiar with doing these checks?
