When I am driving at highway speeds and the car is coasting in a straight line there will be an occasional knocking noise from the front suspension, I believe the driver's side. It is inconsistent and almost random as to when and how bad it is. I originally thought it was a ball joint or tie rod end but was told with complete certainty that it was my sway bar bushings. The only problem is that my car (listed above GXE model) doesn't have a front sway bar so therefore it can't be the issue. I am hoping to pin down the issue, so I don't have to just go through replacing part after part looking for the actual problem. Thanks in advance.
Nov 14, 2022 at 1:59 PM
