While driving the car vibrates and there is a clicking noise, suspension issues?
2013 KIA OPTIMA
108,700 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
8POLLYWOG
My car vibrates and makes clicking noises at highway speeds.
Apr 10, 2021 at 7:31 AM
Most times, a vibration is caused by a tire balance issue, a bent rim, or even uneven tire wear, Are the tires in good condition and properly balanced? Also, is the sound loud enough to record and upload for me to hear? Is there anything that changes the noise, for example when you apply the brakes or while making a turn?
Let me know. Also, try this. In a safe area where the is a lot of room, turn the steering entirely left or right and then pull out. See if you hear a clicking sound. If you do, it is likely a CV joint that is going bad.
Here is a link that describes what a CV joint is:
https://www.2carpros.com/articles/how-a-cv-joint-works
Also, inspect the tires for condition. See if there is any uneven wear. Take a look through this link as well:
https://www.2carpros.com/articles/how-car-tires-work
Apr 10, 2021 at 8:27 PM
