Suspension issue
2007 MERCEDES BENZ C230
108,000 MILES • V6 • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
Something is loose/worn out up front, whenever I step on the brakes it shakes, not the same shake as when the rotors are wrapped, and I know Benz has issues with suspension, raising each front wheel and wobbling it side to side gives free play, can't pinpoint to which it is , whether it is a ball joint, lower control arm, or anything else, whenever my helper moves the steering slightly while raised I hear the play, if the free-play is at the 3 and 9 vs 6 and 12, what is the problem usually?
Dec 14, 2019 at 4:05 PM
When you feel play from left to right (3 to 9), most likely it is related to a tie rod end. There is an inner and outer on both sides. If you look at pic 1, I circled both. I = inner O = outer. In the center the two screw together.
In pic 2, I highlighted the inner so you can get a better idea of how it is attached. At the right end you will see threads where the sleeve that attaches the two together. At the other end, the left, is where it goes into the rack and pinion.
When you move the wheel back and forth (3 - 9), check both ends to see if that is where the play is located. Let me know what you find and I[ll give you directions for replacement.
Dec 14, 2019 at 7:44 PM
NASER NASER
  • 836 POSTS
Ya and aware, but how do i know it's the inner when i can't see it with the boot on?
Dec 14, 2019 at 7:50 PM
You will see play without the outer moving or the steering. I usually have someone move the wheel while I hold my hand on it. That way I can feel if there is a clunk or movement.
Dec 14, 2019 at 10:33 PM
NASER NASER
  • 836 POSTS
That is what i felt just wanted to make sure. Thanks
Dec 15, 2019 at 6:26 AM
Happy to help. Let me know if you need anything.
Dec 15, 2019 at 5:21 PM
