Suspension
2007 DODGE MAGNUM
140,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
UNISYS1
  • 4 POSTS
Replaced my rear upper and lower control arms. I could not replace the upper aft control arm because the manufacturer installed bolt head side next to gas tank, no way to get out without cutting bolt. I only replaced 3 arms. Now the rear end when I hit bumps on road and highway tends to wobble. Is there an adjustment that. Needs. To be done?
Oct 3, 2019 at 9:27 AM
94 TRANSAM
  • 680 POSTS
Hi and welcome.
Can you tell me, is it an SE or an SXT so I can look up the suspension?
Thanx, Rich
Oct 3, 2019 at 10:10 PM
UNISYS1
  • 4 POSTS
Sxt
Oct 4, 2019 at 9:38 AM
94 TRANSAM
  • 680 POSTS
As I went through the options for your car I also found out there is RWD or AWD so I don't know which you have. Below is a diagram. If this is your suspension then there are no adjustments.
These are not commonly replaced parts, may I ask why you had to change them so I can get a better picture of what is going on?
Rich
Oct 4, 2019 at 5:34 PM
