After mechanic press in a new wheel bearing, I cannot fit the caliper bracket over the rotor?
2007 SCION TC
170,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
ARIMAWI
I recently took off the knuckle on my car and had my mechanic press in a new wheel bearing. When I went to put everything back together, I couldn’t fit the caliper bracket over the rotor. I even removed the bracket from the piston, and it still won’t fit over. The strut bolts, axel nut, tire rod castle nut and lower control arm bolts are all torqued properly. Not sure what the issue is. Is the hub not pressed in all the way? Because I don’t have nearly enough clearance.
Sep 18, 2022 at 1:12 PM
Did you depress the caliper? What happens is while the job is apart the caliper can fill with fluid closing the gap in between the brake pads.
Check out this video to show you how to reset the caliper:
https://youtu.be/j8YwfSKEzZo?t=402
If this is not the problem then the bearing is not installed correctly, this video will show the correct steps for doing the job:
https://youtu.be/_FzmmBoa4Tg
Sep 19, 2022 at 12:26 PM
