Sorry, I was away from my computer for a couple days.
It sounds like one of two things. Either something is still bent or more likely you got the incorrect spring. If you send me the last eight of the VIN I can send you the OEM part number of the spring you should have and then you can cross reference that with the assembly that you bought.
If adding spaces fixed the lean issue then the spring is the issue. Since there is really only one way to put the spring in, I don't see how it could be installed incorrectly. Also, adding the spacers is what caused it to ride stiffer over bumps.
Just let me know what the VIN is and we can go from there because the incorrect spring explains everything. Thanks
Sep 2, 2019 at 2:37 PM
