I have a few things wrong with Mr. front end suspension and I wanted to know what is the most important thing to fix so I don’t have a problem driving to work and back. My sway bar bushings need to be replaced and they are out of the mounts and my rack and pinion is leaking power steering fluid I need to replace a boot on my driver's side CV joint axle I need a lower control arm drivers' side and I can't afford it all at once. which part should I fix first in order to be safe?
Nov 27, 2022 at 1:47 PM
