Surging and backfiring through intake at start up
2001 FORD RANGER
200,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
KEVIN HUDSON
As soon as engine cranks. It begins to surge and backfire through intake. I have replaced throttle sensor and map sensor already. New plugs and wires, new coil. The problems still there. Any idea where to look next?
Mar 25, 2018 at 7:47 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The backfire can be because of several things, such as a jumped timing chain/belt, a intake manifold vacuum leak, an intake valve not seating all the way, a blown head gasket. Or even a too lean fuel mixture, maybe due to weak fuel pressure so I would check the fuel pressure, check for any fuel injector trouble codes or any codes for that matter.
Then, completing a engine compression test to rule out the timing chain/belt, the intake valve not seating and the blown head gasket. If all the cylinders are good and about even, then I would suspect an intake manifold vacuum leak.
Mar 25, 2018 at 8:16 AM
KEVIN HUDSON
It started all at once one morning when cranked it up to warm. Compression is good and i have looked for vacuum leak. I have not checked fuel pressure yet. But will. Keep thinking it is running lean on fuel. Timing is also correct.
Mar 25, 2018 at 8:42 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Are you getting any trouble codes for the o2 sensors?
Mar 25, 2018 at 8:50 AM
KEVIN HUDSON
Not getting any error codes.
Mar 25, 2018 at 6:51 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
The fuel pressure should be 60-65 psi KOER and/or KOEO.
Mar 26, 2018 at 8:00 AM
