Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Contour
Engine
Symptoms
Surge
Engine surging
2000 FORD CONTOUR
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
RANDYCARROLL
MEMBER
1 POST
FOLLOW
while in drive engine revs up, while stopped with foot on brake engine revs high. while in park no issues with idle.
Oct 11, 2021 at 1:14 AM
CERTIFIED EXPERT
Good morning,
This sounds like a throttle body issue not regulating the idle as it was designed to do.
https://www.2carpros.com/articles/engine-idles-too-high
You can try cleaning the throttle body to see if it helps but if not, then it will have to be replaced. I attached the instructions for you below.
Oct 11, 2021 at 1:39 AM
