Oh wow, hard to believe all this caused was a little surging. I do wonder if this would have showed up on a cylinder leak down test, or possibly a running or cranking compression test. I can understand how the cam was semi locked in place, but even at the breaking point, I dont see anywhere that looks like it was lacking oil at the cap location, or even any worn lobes. So the right end there, thats where the cam actuator is on this engine correct? And the cam sensor is at the other end where the notches are.
And you didnt find any stuck valves or anything like that on the broken side of this?
Its difficult to say is the metal was porous at the breaking point, since obviously there was some movement against the two broken ends together, I see some metal flakes inside the holes. It looks like it might have just been a manufacturers defect, but I would really inspect for anything that could have caused this. Maybe still do cylinder leak down testing to make sure no valves are effected, you dont want to get this all back together and find out it now sets misfires codes and something else Id be concerned with is all that metal flaking, Im sure some of that migrated into the oil journals and down into the oil pan.
Just off hand, and checking some other information, I found some mechanical causes of this such as a valve spring, rocker arm seized up or connecting rod coming loose, but I think you would have heard some thing like that, I mean a rod thats loose would be making some serious noise. And the breaking point does not look like there was a lack of oil there, it doesnt look burned or gouged where that cap was. And camshaft bearings will make some serious screeching noises when they start to go bad. I had one that I was almost positive it was the serpentine belt screaming, but it turned out to be a cam bearing.
I did a search too just to see if there were any other causes I wasnt thinking about.
Thank you for sharing these pictures though,, very interesting case study, its a first for me, considering there were not codes, I assume it wasnt making any apparent noises either.
I also wonder if this engine had been apart before, and something wasnt torqued to spec, thats something I else I saw. If dont find any other issues, I guess we go with manufacturer defect.
Are you planning on just replacing the cam? If so, I would measure the clearance on that cap where it broke. Id use Plastigauge to do it, if I spelled that correctly. I dial bore gauge would work, but the plastigauge would give a more accurate reading. You might even want to cut open the oil filter and see how much metal particles are in between the layers of the filter. Hopefully the engine is damaged. But keep me in the loop as you go, and thanks again for posting the fault. I really appreciate it. Not the outcome we thought at all.
Apr 8, 2025 at 9:42 AM
