The rear belt runs the alternator. Without that one, the car will run on the battery for roughly a half hour. The front belt runs the AC and power steering. You won't have power steering assist. That is mainly missed at lower speeds. You won't notice it at highway speeds.
What you can expect is for power steering fluid to burp out of the reservoir and make a big mess. Turning the steering wheel pushes the fluid up to the reservoir, but without the pump running, no fluid goes back down to the steering gear. Once the belt is replaced, the fluid must be refilled, then the system has to be burped. Often that takes nothing more than running the engine and turning from side to side a few times. Recheck the fluid level a day or two later.
May 10, 2024 at 4:51 PM
