Sunroof and air conditioner not working
2005 MAZDA 3
125,703 MILES • 2.3L • 4 CYL • 2WD • MANUAL
ALISHA26
My sunroof wont open, it does not even make a sound when you push the buttons and the air conditioner is blowing hot air.
Aug 13, 2016 at 1:26 AM
HMAC300
  • 48,601 POSTS
check fuses then see if power goes through the switch it may be the unit itself which a mechanic would need to look at . see picture.
Aug 13, 2016 at 5:47 AM
ALISHA26
Okay and what about the air conditioner?
Aug 13, 2016 at 6:00 AM
HMAC300
  • 48,601 POSTS
sorry misread it . check to see if the large pipe under hood is cold if it is then try pulling HVAC fuse inside car it may be a temperature actuator if not it is probably out of Freon so a mechanic would need to look at that due to a leak.
Aug 13, 2016 at 6:13 AM
