If you have water leakage the issue is more likely to be plugged drains as the seals are more for wind noise than stopping water. Weed eater string works pretty well to go down through the drains and push out any dirt/crud in them. Just be careful as you can push the tubes off the ends and then you have to drop the headliner to get to the tubes.
As for replacing the seals, you simply pull the old one out of the groove and off the lip in the back. The new ones can be installed upside down so be sure to look at the original before you remove it so you do not flip it over.
There is an outfit called mercedessource.com that has seals and seal kits that come with any tools and the special grease to keep them working properly.
Feb 16, 2018 at 10:58 PM
