Sunroof not opening
2013 FORD EXPLORER
270,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIM JENKINS
My sunroof will not open but the sun shade does, but only half way.
Feb 10, 2021 at 10:42 AM
There could be an issue with the switch or the control module. However, I need you to check something simple first.
Under the hood is a fuse box on the left side. Locate fuse 8 and confirm it is good. In addition to checking the fuse, I need you to confirm there is power to it.
Here is a link to help:
Also, I attached two pics below. Pic 1 is from the wiring schematic. The second pic shows where the fuse is located in the fuse box.
Take care and God Bless,
Feb 11, 2021 at 4:28 PM
