Sunroof is not working
2016 FORD EXPLORER
110,000 MILES • 3.5L
ABOONE48
  • 6 POSTS
Sunroof not working.
Mar 7, 2022 at 3:48 PM
Does anything happen when you try opening it? If not, I need you to check two different fuses. Both fuses are located in the fuse box under the left side of the dash.
Fuses 23 and 27 are the power supplies. Fuse 27 runs the motor to open the sunroof.
If you look below, I attached the wiring schematic for the circuit and a pic of the fuse box. I highlighted the fuses for you.
I need you to check those fuses first. If they appear good, then it is important to check if they are getting power. Here is a link you may find helpful:
See pics below.
Mar 7, 2022 at 7:33 PM
ABOONE48
  • 6 POSTS
I will check those two in the morning. It’s closed now and nothing happens with the switches. I replaced the motor on Saturday and that’s when all this began.
Mar 7, 2022 at 7:37 PM
Chances are a fuse failed. Regardless, let me know what you find. Also, let me know if there was an electrical issue that led you to replace the motor.
Mar 7, 2022 at 8:16 PM
ABOONE48
  • 6 POSTS
Sorry for the delay Joe. It rained all day yesterday, so I had to wait. Both fuses are intact. No failure to start with. Drains got clogged and water got the motor is my suspicion. Everything worked fine up until that point.
Mar 9, 2022 at 3:10 PM
Did you confirm there is power to and from the fuse?
Mar 9, 2022 at 4:15 PM
ABOONE48
  • 6 POSTS
Yes sir. Checked for power and all seemed good. Did disconnect the battery and tried the switches again and it acted like it worked momentarily then nothing again. Wondering if maybe the circuit board in the new motor has issues.
Mar 9, 2022 at 5:55 PM
That is a very good possibility. Do this. At the motor connector, check to see if there is power at the blue wire with a red tracer. If there is, then you can check the violet wire with a white tracer and the violet wire with a brown tracer for continuity to ground when the switch is actuated. If you have both power and ground, the motor is bad. (See pic below)
If there is no power, we need to trace the blue/red wire for an open. If there is no ground, then the switch may be the issue.
Let me know what you find or if I can help in any way.
See pic below.
Mar 10, 2022 at 4:49 PM
ABOONE48
  • 6 POSTS
Will do! Another question. I see there are two motors. Is one for the glass and one for the shade? I changed the one above the driver's seat.
Mar 10, 2022 at 5:15 PM
It sounds like you got the correct one for the glass to open. The one on the passenger side is for the shade.
See pic below.
Mar 10, 2022 at 5:41 PM
