Sugar in gas tank?
2013 TOYOTA TUNDRA
70,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
VICTORIA GUERRERO-SANCHEZ
Hello, I have the truck listed above and I found out someone had put sugar in my tank. I already dropped the tank, cleaned out the lines, and replaced filters. So far after all the replacements and cleaning I've done I tried to turn it on, and the engine turns on but doesn't stay on; it sputters out and sounds like there may be sugar in the engine how can i get my truck running again? any advice?
Dec 25, 2023 at 11:06 AM
DOCHAGERTY
  • 9,603 POSTS
Your injectors are most likely clogged.
Dec 25, 2023 at 7:28 PM
Depending how far the sugar has gone, it sounds like you are going to need fuel injectors, but can I ask if the security light is flashing? Also, I don't think the sugar can get into the engine, it would just clog the fuel injectors, let's run the codes to see if any are stored.
Please upload videos of the problem so we can see what's going on so we can get it fixed for you.
Dec 27, 2023 at 11:44 AM
