My car listed above ion 2, will not crank. Just one day poof started it drove less than 2 miles turned off came back to it 10 minutes later and nothing. All dash lights, buzzers, lights, windows, radio work. Battery will not jump nor charge as it reads 12v when hooked to charger. Replaced starter and ignition switch all fuses and relays are good. I did have to replace 4 fuses in the engine compartment fuse box. 38,42,43,46 all 30 amp J Case fuses.
I also did the relearn sequence for the starter. Passlock is always on and solid whether the car is running or not , locked or not. Service vehicle (flashing)is always visible at the dash as well when keys on and when it use to crank/start. I did have key fob/auto lock issues few weeks before I this happened. Changed battery but still only passenger door. Ran fine until this.
Sound familiar at all??
Thank you.
Stephanie
Thank you.
Stephanie
Jun 12, 2021 at 9:54 AM
