1985 Subaru Wagon Doesnt want to start/acts like its cold?
1985 SUBARU WAGON
FRANK THE TANK
Engine Mechanical problem
1985 Subaru Wagon 4 cyl Two Wheel Drive Manual HIGH miles
It Just Started To get cold and I should have waited a little longer to go. now its acting as if it were to cold for it to start. any ideais?
Nov 15, 2009 at 11:05 AM
MERLIN2021
  • 17,250 POSTS
Can you explain in detail what is happening?
Nov 15, 2009 at 11:12 AM
FRANK THE TANK
[quote:19e0e0dbfc="merlin2021"]Can you explain in detail what is happening?[/quote:19e0e0dbfc]
It will run for a sec, then just stop. I have to keep my foot two the floor wsith the gas pedal to even get it to do that. Befor it did that it was going real slow in all the gears and it would ask me to shift early (on the control pannel) and sound as if it needed it? can you help me out?
Nov 15, 2009 at 11:55 AM
MERLIN2021
  • 17,250 POSTS
I think the best place to start is a compression test.. https://www.2carpros.com/dia/how_to_check_compression.htm Follow this link, you migth have jumped a tooth or two on the timing belt.
https://www.2carpros.com/forum/automotive_pictures/62217_compression_Specs_1.jpg
Nov 15, 2009 at 12:47 PM
