2005 Subaru Outback Vent seems to not open.
2005 SUBARU OUTBACK
55,000 MILES • 6 CYL • AWD • AUTOMATIC
JOEST1100
When I set the switch to allow outside air in, it does not seem to operate. All I seem to get is hot air, even with the temp control on both sides turned all the way down. Is there something stuck closed? AC and heat work fine. Just no outside air.
Sep 29, 2010 at 8:01 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
sounds like you have a faulty switch/intake door actuator-motor/wiring fault
Fault :- Unable to switch suction vents
1 ...Air inlet select switch
2 ...Intake door actuator
3 ...Wire harness
Sep 30, 2010 at 4:21 AM
