2003 Subaru Outback transmission modual
2003 SUBARU OUTBACK
15,000 MILES • 4 CYL • AWD • AUTOMATIC
WANING
The transmission doesn't want to shilft into overdrive which cause either it to shift hard into the overdrive or the oil temp light comes on. They replaced the sensor that tells the transmission to shift and it worked the first time and started to work on the second time but after a week it stopped and has been acting up since. If we pull over and shift the car into park it resets the transmission and shift ok then. What causes it to act up the most is when it down shifts below 40-45 rmps. Do you have any ideas.
Jul 8, 2008 at 11:04 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
40-45 Rpms? 4000-4500 Rpms? The redline should be 6000. What kind of vacuum modulator did you buy? Did you replace it with the correct color? Is the trans properly filled with fluid? Does the overdrive shift linkage move freely?
Jul 8, 2008 at 11:44 PM
