This tech bulliten may help. DISC BRAKE PAD MODIFICATION TECHNICAL SERVICE BULLETIN Reference Number(s): 06-33-04, Date of Issue: January 15, 2004 Related Ref Number(s): 06-33-04 ARTICLE BEGINNING INTRODUCTION The purpose of this bulletin is to address unevenly or prematurely worn brake pads. There is the possibility that the pads are too tight in the caliper and have insufficient clearance as a result of rust buildup and dirt. If that is the case, the backplate of the disc brake pads will need to be slightly filed no more than 0.1mm (0.0039") on each end to remove the rust. REPAIR PROCEDURE/INFORMATION Be extremely careful when filing the backplate of the inner and outer brake pad. Make sure that both ends are filed evenly; do not file shorter than the dimensions shown below (Fig. 1 & Fig. 2 ). Failure to do so will create a rattle or clank noise. After filing, make sure to apply grease on both ends of the backplate where filed. SUBARU: 2001-2003 MY Subaru Vehicles NOTE: THE FOLLOWING PROCEDURE IS NOT APPLICABLE TO NEW BRAKE PADS. (4) Applicable up to VIN 2*633636
Front:
REAR:
Sep 12, 2009 at 12:02 PM
