2001 Subaru Outback Strong vibration
2001 SUBARU OUTBACK
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
DANFIRE333
Hi, I have a 2001 Outback VDC. Lately, my car started shaking like if the wheels where misbalanced. But, They are ok. Shaking is at its stongest at about 55 miles/h. But, if I release the accelarator or brake, the shaking stops. Can you give me some advise?
Thanks
Jan 10, 2009 at 7:29 AM
SERVICE WRITER
  • 9,123 POSTS
Sounds like it is in the driveline. When the power is transfered to the wheel is when it is happening, meaning the load of power is on the driveline. I would look at the axle shafts for any obvious signs suchs as boots leaks or torn to start.
Jan 10, 2009 at 7:36 AM
BARNETJA
have you changed the belts on your car? if so they maybe to tight. when it is idling look at the crank pulley, see if looks worped if so the belts are to tight
Jan 31, 2009 at 11:45 AM
DANFIRE333
Thanks, finaly, it was driveshat bearing. Had them replaced and everything went ok.
Feb 1, 2009 at 1:32 PM
