2001 Subaru Outback Engine tapping sound
2001 SUBARU OUTBACK
68,000 MILES • 4 CYL • AWD • AUTOMATIC
SNOBRDRBUM
When you start up the car it was make a constant tapping sound whne u rev it up it speeds up. while driving around it still makes the tapping noise right along with the rpms get high its speeds up. but after it gets warmed it almost goes completly away. is this just from heavy oil and being cold? or is it a lifter gone bad? or is it worse? ive heard many dif things that it could be. i also heard that if u run some sea foam threw a couple times that should help with the tapping.
Feb 3, 2009 at 2:12 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:88ac516711="SnoBrdrBum"]Engine Mechanical problem
2001 Subaru Outback 4 cyl All Wheel Drive Automatic 68000 miles
When you start up the car it was make a constant tapping sound whne u rev it up it speeds up. while driving around it still makes the tapping noise right along with the rpms get high its speeds up. but after it gets warmed it almost goes completly away. is this just from heavy oil and being cold? or is it a lifter gone bad? or is it worse? ive heard many dif things that it could be. i also heard that if u run some sea foam threw a couple times that should help with the tapping.[/quote:88ac516711]
What weight oil are you using?
I am pretty sure your vehicle calls for either a 5w30 or a 5w20.
It could also be a bad or week lifter.
Feb 3, 2009 at 2:19 PM
MIKE H R
  • 3,094 POSTS
The subaru boxer engine is known for its tapping, mine has been doing the same thing ever since I bought it used over two years ago. I have driven from new york to south carolina a number of times with it and it still does the same thing. I run about 80 lbs of oil pressure when I start it but irt goes down to 40 when warmed up. you can pull the engine and fix the lifters or like me leave it alone. When it is warmer out it will not be so load when starting. I have a friend that has a year old subaru outback and it does the same thing. the funny thing is that it is not all the engines that do this.
Feb 7, 2009 at 8:14 AM
