2001 Subaru Outback alternator output
2001 SUBARU OUTBACK
94,000 MILES • 4 CYL • AWD • AUTOMATIC
RAY ERNST
My repair shop installed a new 130amp alternator instead of a 90amp as noted in the owner's manual.
Are there potential risks to my electrical system components using an alternator with higher amperage?
Thank you
Jul 10, 2008 at 12:40 AM
KHLOW2008
  • 41,814 POSTS
Hi Ray,
The higher amperage means a faster charging rate and should not affect anything except maybe a heavier load felt at idling when more current is needed from the alternator.
If you use a lot of accessories such as amplifiers, spot lights, it would be better for the battery.
Jul 14, 2008 at 11:16 AM
