I have a 00 subaru outback 2.5. I have been having a continuous problem with the idle. At start it revs to 1200rpm then settles like normal. but when in gear at idle it idles high at 1200 then bottoms out and chuggs feeling like it will stall out and occasionally stalls while in gear aroung 3-400 rpm. i had the 200,000 mile service done by the dealer at 186,000 and have replaced every componet at the manufacturer specified intervols according to subaru's specs. oil 3,000 trans 15,000 diffs 15,000 etc. I replaced the fuel filter again as good measure and the problem still is occuring. Should i replace the throttle position sensor?? Thanks for all the help.
May 9, 2008 at 2:23 PM
