I tried to replace my cv joint, but i failed. I got the axle nut off and removed(i think) the outside tie rod. This released the rotor and brake assembly. I got the axle to slide back but not far enough. Do i need to drop the ball joint or take off the the strut in order to create more room? I also couldnt get the rotor off, should it be off? Also, how hard is it to change the a/c and alt belts. Thanks
Apr 13, 2008 at 8:39 PM
