1999 Subaru Outback clutch pedal stays on the floor
1999 SUBARU OUTBACK
150,000 MILES • 6 CYL • 4WD • MANUAL
TANDEN
clutch has been replaced, clutch master cylinder has been replaced. after bleeding the system thoroughly...the clutch will work well until driving a couple blocks then the pedal will go to the floor and stay there, the snout that the release bearing rides on is slightly worn, and the release fork has no preload on the slave cylinder it just rides where it rides untill higher rpm then the fingers on the clutch push out against the bearing and fork which rattlesw against the slave working it back and you lose pedal on next aplication untill you work it 6 or 7 times then will work for a while again...does this sound like a problem with the slave or a problem caused by loose bearing on transmission snout or something else? Help please!
Jun 25, 2009 at 11:44 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds more like the slave cylinder is bad.If the pedal comes around when you pump it, then it is sucking air somewhere, if al else has been replaced, then try a slave cylinder
Jun 26, 2009 at 7:38 AM
