1999 Subaru Outback air induction/MAF
1999 SUBARU OUTBACK
126,000 MILES • 4 CYL • AWD • AUTOMATIC
AHYDE87
I used Seafoam to clean my induction system and poured it overtop of my MAF. immediately it ran rough and stalled. So i did some diagnosing and that i came to the conclusion that i fried the sensor. When it was plugged in it would not run more than 5 seconds and as soon as i tried to give it gas it would die. There also was a faint electrical noise when i pressed the throttle. So i unplugged the sensor and it ran better but still slightly rough. I bought a used MAF sensor off of ebay and it did the same then so i thought i bought a bad one and now i bought a brand new sensor and it still does all the same things.
May 15, 2010 at 7:29 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Thank you for the donation,
first things first, go get a scan done and check for any unresolved fault codes, you don't get check light son with all codes, do this and report you findings for more assistance.
mark (mhpautos)
May 17, 2010 at 12:57 AM
AHYDE87
the fault code is P0102. MAF circuit low input
May 17, 2010 at 5:12 AM
MHPAUTOS
  • 31,937 POSTS
Check that the wires into the MAF sensor plug are tight and that there's no corrosion on any of the pins, if that is ok, do a continuity check of each wire back to the ECU.
mark (mhpautos)
May 17, 2010 at 6:04 AM
