1998 Subaru Outback PARKING LIGHTS WILL NOT CUT OFF
1998 SUBARU OUTBACK
101,068 MILES • 6 CYL • 4WD • AUTOMATIC
DAVIDBDIXON
MEMBER
1 POST
FOLLOW
PARKING LIGHTS WILL NOT CUT OFF UNLESS YOU KILL BATTERY JUST STARTED
Jan 17, 2008 at 5:08 PM
MIKE H R
CERTIFIED EXPERT
make sure the positioning light switch is turned off. Do the rest of the lights work ok?
Jan 17, 2008 at 8:56 PM
WOODYREEDY
MEMBER
There is a switch on top of the sterring column that turns the parking lights on and can only be turned off via this switch (unless you disconnect the battery). Is this switch turned on?
