1996 Subaru Outback Subaru 1996 outback legacy 70.000 miles
1996 SUBARU OUTBACK
70,000 MILES • 4 CYL • 4WD • AUTOMATIC
A_SANNINE
  • 7 POSTS
Problem
My Subaru 1996 outback legacy 70.000 miles has been dying at stop lights (or long idled portions of time) and it is little hard to start again ,
skiping on high ways ( not always ) , most of the time this problem happen when the car is warm , I would say after driving it for more than 10 miles , no trouble codes in memory though .
problem doesn't happen all the time though , every once a while .
Any help
Thanks
ps: known car hardly been used for the past 5 years, it is like new shape , rides like a dream , problem started 10 days ago .
Jun 4, 2010 at 8:14 PM
MHPAUTOS
  • 31,937 POSTS
hi there,
Thank you for the donation,
I would as a starting point replace the fuel filter and closely inspect all the vacuum hoses, did you actually do a scan? not all fault codes give a check light, i would also get the coil output voltages check with the engine hot as you can get a coil breaking down when it has warmed up, start here.
mark (mhpautos)
Jun 4, 2010 at 9:34 PM
A_SANNINE
  • 7 POSTS
how do u check the coil output voltages ?
i have an ohmeter , will that work ?
i took the car to autozone and they pluged it to a small hand held scaner and no code found ?
thanks
Jun 4, 2010 at 10:19 PM
MHPAUTOS
  • 31,937 POSTS
The coil output will have to be check with an oscilloscope, and preferably on a dyno to simulate the actual engine load, this is the best way to check a coil an ohm meter test will not show any load failure.
mark (mhpautos)
Jun 5, 2010 at 12:05 AM
A_SANNINE
  • 7 POSTS
checked vacuum hoses all good
changed fule filter , problem still the same
u think i should change spark plugs ?
thanks
Jun 5, 2010 at 11:24 AM
MHPAUTOS
  • 31,937 POSTS
A new set of plugs won't hurt but i doubt that that will fix the problem, i am leaning more to a coil problem, also have you ever had the injectors cleaned?
Mark
Jun 5, 2010 at 6:21 PM
A_SANNINE
  • 7 POSTS
i am gonna do that during this coming week
i hope that will take care of that problem ,
thanks
Jun 5, 2010 at 6:57 PM
MHPAUTOS
  • 31,937 POSTS
Keep me up dated with the results, i will do a bit of research and let you know if i come up with anything else of interest with this problem.
Mark
Jun 5, 2010 at 7:01 PM
A_SANNINE
  • 7 POSTS
thank u so much
Jun 5, 2010 at 7:38 PM
A_SANNINE
  • 7 POSTS
injectors cleaned
pcv valve replaced
same problem
maf cleaned
iacv cleaned
when it goes down now hard to start (some times )
what do u think
thx
Jun 8, 2010 at 3:08 PM
MHPAUTOS
  • 31,937 POSTS
I am still of a mind that this is electrical, one check you can do, when it will not start easily, after a few cranks, pull a plug, if it is wet and sooty, more evidence that it is electrical.
mark.
Jun 8, 2010 at 4:37 PM
A_SANNINE
  • 7 POSTS
MAF WAS ON THE WAY OUT
I CHANGED IT AND PROBLEM FIXED
THANKS
Jul 8, 2010 at 5:08 PM
MHPAUTOS
  • 31,937 POSTS
Good result, thank you for using 2car pros.
Mark (mhpautos)
Jul 10, 2010 at 5:19 AM
