1996 Subaru Outback slow starting
1996 SUBARU OUTBACK
156,000 MILES • 4 CYL • AWD • AUTOMATIC
MOJO121
I have replaced the battery and the alternator. Seems like the trouble is in the electrical system, as when I accelerate, the lights brighten and the blower motor speed increases. I have returned 1 new alternator already (presumably bad). Is their another part of the charging system I am overlooking?? The car is VERY slow to start, and at 1 or two points has refused to start. Just a very slow cranking. It has been cold, but we never had this trouble before and I am afraid it will let my wife down. please help. -Joe
Jan 4, 2010 at 8:35 AM
RACEFAN966
  • 5,029 POSTS
I need to know if it is a legacy or impreza outback. Get back to me and I will look over the wiring diagram for the starting and charging system and see what we can figure out from there.
Jan 4, 2010 at 12:33 PM
MOJO121
Legacy wagon. thanks.
Jan 4, 2010 at 1:11 PM
RACEFAN966
  • 5,029 POSTS
Ok before we get to far into this I would like you to check a couple of fuses. These fuses are for the charging system. In the underhood fuse box on the left side there is a slow blow fuse, it is fuse number 4 and is 45 amp. The other fuse to check number 15 in the fuse box inside the car it is a 10 amp. If these fuses are good then I would like you to use a digital multi meter to check the white wire at the back of the alternator see if it has power. Let me know what you find ok.
Jan 5, 2010 at 10:08 AM
