Man that sucks,If its leaking any repair in the car will probally be short lived.I dont know that this is really a job you should tackle in your drive way.The vehicle needs to raised up high enough to remove the rear suspension and rear diff(if its AWD).All of the electrical and lines to and from the pump and sending units are accessd from inside the car after you remove the access panels .The fuel fill and return hose can kind of be a pain to remove as well.The drive lin ,heat shields and in some cases the exhaust may have to come out as well.Hope that helps
Mar 13, 2007 at 11:22 AM
