Oil on Spark Plugs
SUBARU
JCWOOD07
I just bought a 99 Subaru Forester S, with 90,000 miles on it. I was checking things over and when I went to check on my spark plugs I noticed they were covered in oil. What does this mean and how do I fix the problem?
Thanks
Nov 9, 2007 at 3:47 PM
Do a compression check or a cylinder leakdown test.it will tell you whether its a valves or rings problems
If its a valve-you need a Valve Job and for the rings -reconditioning of the cylinders and ring replacements.
Technically it needs an engine rebuilding-if its the upper part of the engine your lucky only the head/s needs a valve job.
Nov 9, 2007 at 4:09 PM
