miss firing
SUBARU
LIBBYHOVE
diagnosed check engine light on 99' subaru outback impreza sport with 130,000 miles as a misfire of cylinders 1&2. i changed plugs, plug wires and coil pack. after coil pack seemed to run better, but light now flashes several times when over 3200 rpms. Also, the head gasket was replaced 3 months ago and the front of the motor where the belts are at seems to really be shaking now. what else could cause a misfire of the cylinders? Im concerned this is another $1000 if i don't repair it soon but i don't want to get ripped off- thanks
Aug 29, 2007 at 6:00 PM
[quote:ce84e8bd5e="libbyhove"]diagnosed check engine light on 99' subaru outback impreza sport with 130,000 miles as a misfire of cylinders 1&2. i changed plugs, plug wires and coil pack. after coil pack seemed to run better, but light now flashes several times when over 3200 rpms. Also, the head gasket was replaced 3 months ago and the front of the motor where the belts are at seems to really be shaking now. what else could cause a misfire of the cylinders? Im concerned this is another $1000 if i don't repair it soon but i don't want to get ripped off- thanks[/quote:ce84e8bd5e]
Could be a compression /injector/low fuel pressure.
Aug 29, 2007 at 9:40 PM
