HELP ! car quit on road. No fire to 2 rear cylinders
SUBARU
TERRIJOADAMS
Have a 90 Legacy with couple hundred thou miles on it. It's a 2.2 liter w/fuel injection(not turbo). I love this little car and can't afford to go to a shop. It's always ran great and I've never had ANY problems with the motor (well, until now).
Checked/replaced all of the sensors as well as the coils. Ran the diagnostic (from the Haynes manual) and it returned a 24 and 31. Both of these have been checked/changed. Can't run the self-test because the car must be running for this to work. Can't quite seem to get there.
The back 2 cylinders aren't getting any fire.
ANY and ALL ideas, suggestions, HELP you can give me will be GREAAAAATLY appreciated.
Terri Jo
Oct 26, 2007 at 8:30 PM
BLACKOP555
  • 10,386 POSTS
check the fuel injectors by the cylinders they may be dirty and plugged. also check the spark plugs and make sure they are gaped right. The distributor cap may be worn on the points causing improper spark.
Oct 27, 2007 at 8:56 AM
TERRIJOADAMS
The fuel injected car doesn't have a distributor or points.
Oct 29, 2007 at 6:49 PM
BLACKOP555
  • 10,386 POSTS
i mean the metal tabs on the distributor caps. not Points like old time points.
Oct 29, 2007 at 7:03 PM
