Forester fails to start after inital warm up
SUBARU
SOSA
  • 4 POSTS
Subaru Forester 2003
Yesterday, the temp reached -36 Cel ...The Subaru was parked outside without starting for roughly 14 hours. This morning 4am, started with aftermarket auto starter, first shot, no problem. Warmed up 10 minutes, remotely shut it off. 1.5 hours later, tried the auto starter again, nothing, starter was cranking, but failed to start, tried a few times, gave up. Went outside, checked BAT Terminal on Alternator 11.9 volts, Battery 11.9 volts. A little low, but keep in mind, that I tried to start it 3 or 4 times in a row, eventually this will start sucking the battery. (NOTE battery AC delco 2 weeks old)...Although I knew with the voltage that a car boost wasn't going to help, tried to boost, same problem, car cranks, but doesn't start. Came back inside, waited 30 minutes, finally started. I know this is not the alternator or the battery and I am starting to get the feeling that it is the afterarket starter. This only happens under severe cold temps and the Subaru For will always start on the very first shot, but will fail to start 1 hour later, then 30 minutes later will finaly start. This issue has happened 3 times in extremely harsh weather. Right now, the SUB is running in idle with the defrost, heater, fog lights and radio turned on, my BAT terminal voltage on alternator and on battery are fine. Can someone please help? Is this aftermarket autostarter killing my SUBIE?
Mar 6, 2007 at 9:32 AM
SOSA
  • 4 POSTS
Can this be something as silly as Moisture in the ignition system/Spark Plugs?
Someone please advise
Mar 6, 2007 at 10:35 AM
SCUBARU
  • 71 POSTS
In cold you may need to open the throttle while trying to start the vehicle something that isnt going to happen while trying to start with an auto start system.The colder the temp the more fuel the ECM will provide to the engine VIA increased injector pulse width.If while cranking the throttle isnt opened up (cold weather only) the engine can flood.Way to much fuel and not enough air .Causing the fuel to air ratio to be to high.Most likely rather then leting it sit after it cranks and fails to start try flooring it and cranking the vehicle until it clears out .On a fuel injected vehicle when you open the throttle all the way by flooring the gas pedal the ECM will shut off the fuel injectors which will lean out the mixture and also you will introduce much needed air to a flooded engine
Mar 6, 2007 at 11:05 PM
