hi there, i have a 94 subaru legacy its a BG% and the engine EJ2ott, i had blown headgaskets, and a cracked passengers side head which have replaced.we put everything back together and tried bleeding the cooling system, found out we had a toltally blocked radiator, we have replaced radiator and we have tried bleeding cooling system again for about 2.5hours with heater set on max temp using radiator bleed valve, but we are still getting persistant bubbles popping up through bleed valves and radiator filler. is it likely to be a cracked head or are we not bleeding it properly???
Oct 6, 2007 at 4:17 AM
