1998 Subaru Legacy 2.5L, 140 000 miles, standard transmission. Was recently towing a trailer and engine overheated. Topped up coolant, but problem persisted, even when not towing. Reservoir keeps filling, but rad doesn't draw coolant from reservoir. Coolant in reservoir is cold to touch. Had pressure test done on rad, and head gasket test done also. Both came back negative, only problem was the rad cap was not holding recommended pressure. Replaced cap with USED cap, issue persists. Can drive for a few days without problem, then suddenly overheats. Other than replacing the used cap with a new cap, do you have any suggestions for fixing this issue? Thanks!
Nov 13, 2007 at 1:47 PM
