I have a 91 subaru legacy wagon 4 door hatchback, that has the push button height control option. The switch is stuck on, and the vehicle is stuck in the high position, IE very bumpy ride, almost undriveable. I took the vehicle to a repair shop to have the problem repaired they said that I had leaks in the air bags which control the height control, and it would be tons of money to replace the system. I dont care about the height control, and just want it removed or disengaged.
I have tried pulling the fuses and disconnecting the battery to restart the ECU, with no luck.
What can I do, I just want it out of the the high position an driveable again. Can I some how disengage and disconect the switch?
Thanks very much,
Rachel
Thanks very much,
Rachel
May 1, 2007 at 10:41 PM
