i have a 1997 subaru legacy L and the knock sensor is bad where is it located and what is the best and easiest way to change it
Nov 18, 2007 at 3:34 PM
MIKE H R
CERTIFIED EXPERT
the knock sensor is located under the intake manifold on the rear of the engine. it is threaded into the block. careful when removing it as the coolant in the block will run out draining the block
