Engine dies when the car comes to a stop
1982 SUBARU
BIRDGIRL54
Engine Performance problem
4 cyl Front Wheel Drive Manual 193648 miles
Hi! Recently, my car developed a problem where the engine dies when the car comes to a stop.
When I start the engine for the first time after it sits all night, it doesn't die at stops until I've driven maybe 3/4 of a mile or so down the road (I assume because the engine has had a chance to warm up). After that, even if I let it sit for about an hour or two and then restart the engine, it continues to die at stops. If I keep my foot on the accelerator to slightly raise the RPM, I can keep it from dying.
I always put premium rather than regular in the car. Always have. If, for example, the gas station were to accidentally put a lower octane in my car, would this kind of a problem arise?
If not, what might be the cause and how could I fix it?
Thanks in advance!
May 9, 2008 at 11:57 PM
For a start find the EGR valve and clean it out
May 10, 2008 at 12:09 AM
BIRDGIRL54
Thank you! I'll try that and let you know how it goes. Might be a few days. I don't need to drive the car that much.
May 10, 2008 at 9:24 PM
BIRDGIRL54
As promised, I'm getting back to you. It was not the EGR valve, although interestingly, the last time I had this problem, that's exactly where the trouble was. Unfortunately, the problem was in the carburetor. I ended up taking it to my mechanic and he said something about a passage being blocked. So it's rebuild time.
Anyway, thanks again for the suggestion. From past experience, it certainly could have been the EGR valve.
May 29, 2008 at 10:46 PM
