1991 Subaru Loyale Rear Strut Replacement
1991 SUBARU LOYALE
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOAD
  • 5 POSTS
Need to replace the rear struts. I can see how to do it from the repair guide on Autozone, but unsure about how or when to deal with the springs.
At what point do I compress the springs to remove the struts?
After I take off the top bolts? These are in the wheel well.....
Any guidance is appreciated
Jul 6, 2010 at 9:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
after removing the upper and lower mounting bolts the strut should come out. then you use a coil spring compressor to compress the spring and remove
Jul 6, 2010 at 10:17 AM
